gear type hydraulic pump on 580 case LB
Tom Gyger
08-25-2003 18:56:25
I have a straight forward gear pump that reportedly was removed from a 580 loader/backhoe of perhaps mid 70's vintage. All parts appear undamaged and there is no indicatiobn of excess wear, although the pump was supposedly replaced as a warrenty item. We would like to use this pump, however upon assembly the gears will not turn by hand when the end plates are installed and tourqued down. Can anyone tell us who might have supplied this to CASE and where we might locate and exploded view? There is a weblike plastic gasket on one of the end plates that might be the source of our binding, but I fear that we are overlooking a simple "in our face" cause. Removal of apparently surplus parts is rarely the best course of action.
George G
08-26-2003 17:32:43
 Re: gear type hydraulic pump on 580 case LB in reply to Tom Gyger, 08-25-2003 18:56:25
Does it have any numbers or other markings on it ?
GARY B
08-26-2003 16:16:29
My 530CK has a Cessna Pump. The service manual says that after a rebuild use a wrench to rotate pump shaft 10 revolutions. Shaft should then almost be free enough to turn by hand. If friction is excessive, disassemble and inspect for burrs, bent wear plates. When free enough to turn by hand it says to pour hydraulic oil into the larger port and rotate pump a few revolutions. After installing on tractor it says to run at zero pressure for 30 minutes.
Hope this helps some
