SC Starter have gasket?
G. L. Perry
08-24-2003 21:13:09
My SC had a big thick cork gasket on the starter hole, between it and starter. Is this correct? It has about a 1/4" space there w/out it. The mount bolt/pin lines up OK, but leaves the gap. After pulling it, I see the nose was welded and ground, so it must have broken once. The break is ahead of pin hole, so that's not holding it out. I have MM's with same mount type, they don't have a cork gasket there like this has, so didn't think was correct. Now I learn the oil can be in clutch area, so maybe it does have one? Hope the fella who doesn't like my Multi-posts' isn't gettin' angry. WHO Cares!
RandyD
08-25-2003 12:09:26
 Re: SC Starter have gasket? in reply to G. L. Perry, 08-24-2003 21:13:09
Mine was missing and I had to make one by cutting two thin paper gaskets then putting a big bead of the black gasket stuff in between them like a sandwich. I then bolted the starter up but not tight.
Th add to my problem for some reason or another the starter does nor fit in straight but it is a little cockeyed. The gap on the side away from the engine is say 3/8 and the other side 1/4?
Randy
G. L. Perry
08-25-2003 12:53:33
 Re: Re: SC Starter have gasket? in reply to RandyD, 08-25-2003 12:09:26
Mine appeared same way, that's what made me think it was not stock item. I ordered one today from Case dealer, $10.00 for cripes sake! I ordered the valve cover SET from auto parts store, cheaper than dealers. Guess I'll be making the small paper ones for aruond dist drive area or maybe the link you gave earlier.
keith
08-25-2003 02:54:38
The gasket is correct. There is engine oil in the clutch because it is a wet clutch be sure to drain the oil in the clutch housing when you change the oil. The clutch housing will fill itself when you fill the engine up with oil.
