SC gaskets?
G. L. Perry
08-24-2003 20:44:37
I want to replace a lot of gaskets on my SC as I clean up parts and replace. Is there a source other than dealer for these? Seems Case stuff is harder to find, not sure if Case kept it that way or what? I need valve cover, oil screen on pan, distributor drive areas and maybe water pump gaskets and so-on. Might be less costly to get O'haul set or maybe head set for some of these, even though I wont' be opening engine? Where you fellas get yours? OR< do I have to make alot of them? I do have punches to make clean holes, I just hate doing it.
Randy
08-25-2003 12:14:35
 Re: SC gaskets? in reply to G. L. Perry, 08-24-2003 20:44:37
Olsons gaslets is a good place. click on gasket below.
Randy
keith
08-25-2003 02:59:09
I bought a complete engine gasket set from a CaseIH dealer for about $90 that had all of the gaskets for the motor including the head gasket but the gaskets for the transmission and rearend I had to make.
