Timing 1941 DC
John A. Pferdeh
08-24-2003 09:01:41
The manual that I have says there is a hole in the flywheel cover where I can find a D on the flywheel to get TDC on #1 piston. I cannot find that hole or a cover/inspection access. Also, my distributor has a manual spark advance control that is not in the manual that I have. Any info on either of these items would be helpful.
John Pferdehirt
Kingman AZ
JayEyeSee
08-24-2003 10:21:14
 Re: Timing 1941 DC in reply to John A. Pferdehirt, 08-24-2003 09:01:41
The hole is a pipe plug on the right side of the bell housing just below the starter hump. They are hard to see because the run in oil. I would pull #1 spark plug and put my finger over the hole and have someone tap the igniton over. When it blows your finger off it is at TDC. Then you can locate the flywheel mark through the hole to get it perfect. The dist. you have could be off of of a IH or a Allis or a later case. A 1941 wouldn't have a dist. original. Post the #s off the dist and we can find out what you have.
John Saeli
08-24-2003 10:02:42
Hey John; 2 people make this much easier. About level with the starter, back from the starter is a 1/2" pipe plug you will take out. That exposes the flywheel. I take out #1 spark plug, crank engine till you feel compression, then keep a close eye thru that hole for the "DC" mark. It goes by pretty fast. I have a good hot CASE mag for $125.00 which would look much better that that distributor. Good luck!!
