188 D black smoke
Tim
08-24-2003 06:21:59
I have a 580B w/188 diesel. The engine has been rebuilt. New crank,brgs, sleeves,valves,guides, cam brgs and oil pump. The injector pump was rebuilt shortly before I bought the machine. I was told the man that did it was an expert and used all ( stainless parts ?) the injectors were replaced at that time.
The engine runs great, starts on the first rev of the starter.
My only concern is with the black smoke. I don't want to fill up a new motor will soot and/or carbon.
At Idle it puts out a small amount. Any load at all and she really pours out the smoke. I have replaced the air cleaner so I know I,m getting plenty of air.
so It must be getting to much fuel right?
Where should I look next?
Timg
08-07-2005 05:08:03
 Re: 188 D black smoke in reply to Tim, 08-24-2003 06:21:59
Well its been 2 years (can"t beleive that) I wanted to wait til the motor broke in and it has 122 hours on it now and still smokin. I have checked both the timing mark on the flywheel and the marks in the pump window. Both line up TDC. I had to alter a 9/16 box end wrench to loosen the back bolt on the timing pump to advance the timing.I turned the pump about 1/8 inch CCW if sitting in the seat. started it up and I could hear a change right away. It sounded alot stronger and just more like what a new diesel engine should sound like. (if that makes any sense) Anyway It seems like the smoke was less I will have to run it a while before I say for sure.
Thanks
george md
08-25-2003 22:55:10
Tim, Injectors are a slim possibility , more likely pump timing . Check nozzle pattern and opening pressure. Late pump timing will cause the smoke . also could be in time at setup and not advancing due to any of several things. the advance plunger could be in backwards,therefore not advancing ,check by putting plexiglass window on timing window to see if cam ring moves with rpm.It is possible the advance is worn out.Transfer pump vanes could be worn or the springs in them bent or broken , the transfer pump pressure regulator may be hung open or have broken spring , all of these will cause low transfer pump pressure which is what operates the advance plunger ,causing little or no advance.
george
Oldfarmboy Jim
08-25-2003 00:14:53
Tim, You're on the right track. Usually excessive black smoke is caused by: -restriction in the air induction system, or - Injector pump timing incorrect, or - Low engine temperature, or - Faulty nozzles, or - Injector pump delivering too much fuel per stroke. I would suspect the last item. If the rebuild was done in a professional shop, they would have the bench equipment to check that the pump was puting out exactly the correct amount of fuel over a full RPM range, so that shouldn't be a problem. However if the "expert" did the rebuild in his basement without benefit of bench testing, then you could have a pump that hasn't been calibrated and it's just puting too much fuel out per stroke. I'm not aware that you have a choice of stainless parts or not when rebuilding a pump. You get what the OEM or AMM provides. Is this a ROOSA MASTER DB pump? I just rebuilt one of those for a TD340. I don't claim to be an expert, but if you follow the shop service manual for your pump, it's hard to screw it up. The TD340 had been sitting for over 5 years. The metering valve had rust shut and it had a small accumulation of gunk in some of the fuel channels. I stuck with the book closely and got it loosened up and cleaned up. The moving parts all met specs, so I replaced all gaskets and seals and o-rings. Put it back together and the tractor ran right off the bat after bleeding the air and re-charging the injector lines. I never would have undertaken the rebuild without the shop service manual though. Good Luck on yours, Jim
tim
08-25-2003 03:24:07
 Re: Re: 188 D black smoke in reply to Oldfarmboy Jim, 08-25-2003 00:14:53
Thanks Oldfarmboy
I have a full set of Case manuals and they don't go into much detail on the pump.Is the Roosta master manual easy to get? After reading your post I'm going to check the easiest thing 1st and work my way to the hardest. Checking the timing through the window as shown in my manual. Only problem is the loader support arm runs right past the window... quess I'll have to use mirrors or something?
The hoe is not nearby so I can't walk out my door and look. It will be a couple of days till I can get to work on it.
JayEyeSee
08-24-2003 06:41:55
Injecter pump
