Case 530 Tune Up Help???
Jeff
08-23-2003 13:43:16
Hi, I need help giving my Case 530 Construction King Forklift with a 159 gas a tune up. First off what do I gap the Plugs and points at? Is there a trick to the points and condensor?
Now for my dumb question how do I get to the points? There's like a metal cover under the rotor? I don't want to wreck the distibutor. Thank You Jeff.
Jeff
08-28-2003 20:34:34
 Re: Case 530 Tune Up Help??? in reply to Jeff, 08-23-2003 13:43:16
Thanks Dennis, I'll Give that a try this weekend. Hopefully I can remember how to do it all. Thank You Again For the info Jeff.
Dennis/Ohio
08-28-2003 19:31:07
Hi, I doubt if your CK 159 is different from my 530 159. .025 plugs & .020 points. But the timing is a trick of sorts. The distributor will advance some as soon as you start the engine. (learned this the hard way) So, use a test light on the distributor to tell when the points just open with the engine at 4 degrees before top dead center. Or if using a timing light, run the engine at full speed and set the total timing at 30 degrees....(I do total with a light)..Dennis..
