Case VC update
Mike
08-22-2003 19:52:30
Tonight I hauled the new VC home. Everything went well with no problems. I can't wait to get it running. The person I bought it from said it was running about a year ago. Then the battery went dead and he lost interest in it. Any suggestions about what I should do before i try to start it. This tractor will be my first restoration. The sheet metal is in relatively good condition. Only a couple small dents. The only bad area is around the exhaust pipe. Looks like someone took a torch to it and made the hole larger.
Mike from Canada
08-25-2003 07:25:12
 Re: Case VC update in reply to Mike, 08-22-2003 19:52:30
check all of your fluids in the engine. make sure the coolant hasnt leaked down into the crankcase by checking the oil for antifreeze.
the other thing is the fuel. it may have gummed up between the carburetor and the gas tank. or not. it doesnt hurt to check.
hope this helps!
mike
