Cae 530 CK - Fuel Injection Pump
Phil (NJ-AZ-SK)
08-22-2003 18:36:18
I am having fuel problems with my 530 CK �Started this morning and then Quit� Filters Very dirty�Replaced both and Bled Air���.No fuel out of the Pump to Injectors�. Removed �Roosa Master Model DB Injection Pump after noting that the Timing Window was not moving while bumping starter to set up timing�..
Question # 1 .. The shaft can be rotated by hand (with the pump Off) and moves sideways, like a pivot�. I don�t think this is normal as its Keyed�. Does the Key Shear?
Question # 2 I can not turn the Pump, using a Large Screw driver � is this Normal or has the pump failed and also sheared the Shaft Key. (2 problems)
Any help would be appreciated.
Oldfarmboy Jim
08-22-2003 22:03:17
 Re: Cae 530 CK - Fuel Injection Pump in reply to Phil (NJ-AZ-SK), 08-22-2003 18:36:18
Phil, I have a similar injector pump on a TD340. So there may be some differences in the mounting. -The pump should move freely when you insert a large screwdriver in the rotor drive slot. -The shaft should not move with the pump removed unless you have loosened three locking bolts at the gear end of the shaft. -Only the timing line on the governor weight retainer should move when cranking the engine. The timing line on the cam should remain stationary. I recommend getting the service manual for the injector pump and taking it apart to see what's going on. You may save yourself $400-$600 .
Phil (NJ-AZ-SK)
08-24-2003 03:54:02
 Re: Re: Cae 530 CK - Fuel Injection Pump in reply to Oldfarmboy Jim, 08-22-2003 22:03:17
Oldfarmboy, Thanks for the Info... The Pump rotor is frozen.... I found the Gear "Key" was sheared...
Just need to find a Diesel Pump Repair Shop in the South/East Sask.. Case dealer in Minot uses shop in Devils Lake, ND. I would go for a Re-man Pump....
The 530 CK with FEL is a "bear" to work ON... Wish I was a dwarf with Small Hands and Little Tools..
Regards,
Oldfarmboy Jim
08-25-2003 00:23:31
 Re: Re: Re: Cae 530 CK - Fuel Injection Pump in reply to Phil (NJ-AZ-SK), 08-24-2003 03:54:02
You might be interested in this site: >Link
JIM>Link
