300 governor probloms
Gary
08-22-2003 05:06:27
when trottling up the governor seems like cannot find a place to level out it trottles up and down and eventually smooths out. I think it works ok when driving under load but this up and down thing happens only revved up! could it be a spring problom?
Jerry
08-24-2003 06:33:30
 Re: 300 governor probloms in reply to Gary, 08-22-2003 05:06:27
Gary, Sounds like a spring problem. but first check the linkage and make sure it is free. We had a VAC that the cne over the weights can loose on the cam shaft and the wieghts would not work correctly. I hope this will help you.
