Information on Case VC
Mike
08-21-2003 19:39:49
I just purchased a Case "VC" tonight. I'm having a hard time finding information on this tractor. What is the horsepower rating? What type of electrical system does it have? I'm asuming its a neg. ground. How much does it Wieght?
Mike
08-22-2003 19:33:10
 Re: Information on Case VC in reply to Mike, 08-21-2003 19:39:49
Thank you for all the information and comments.
Mike from Canada
08-22-2003 06:03:54
heres an exerpt from the Nebraska Tractor tests:
1940 model VC used for the test, "pulls one to two 12-inch plow bottoms under average soil conditions.
Rated Brake Horsepower: 22.07*
Rated Drawbar Horsepower: 15.07*
Maximum Brake Horsepower: 24.48
Maximum Drawbar Horsepower: 18.55
Cylinders: Four: bore, 3 inches; stroke 4 3/8 inches
Normal Engine Speed: 1,425 rpm
Ignition: Edison-Splitdorf magneto with impulse coupling
Carburetor: Schebler Model TSX43, 1 inch
Road Speed: (On rubber) 2 2/3 miles per hour, 3 2/3 miles per hour, 4 2/3 miles per hour, and 10 miles per hour
Total Weight: 4,290 pounds
Front Wheels: 5.00x15 (rubber)
Rear Wheels:9.00x32 (rubber)
Rear Wheel Tread: Adjustable, 44 inches to 84 inches
*Horsepower ratings from Nebraska Test results; tractor operated on gasoline"
if you feel you want something like a VAC instead, i'll gladly trade mine for your VC (tee hee)
hope this helps!
mike
MattWV
08-22-2003 06:39:53
 Re: Re: Information on Case VC in reply to Mike from Canada, 08-22-2003 06:03:54
Mike,
How does the VC compare to the VAC?
Thanks
Matt
Mike from Canada
08-22-2003 07:55:04
 Re: Re: Re: Information on Case VC in reply to MattWV, 08-22-2003 06:39:53
depends on how you compare them.
they are relatively the same tractor. visually anyway.
Farmers hated the V series because the Edison-Splitdorf mags were poor. they could be hard to start, and once they were started they became hard to keep running.
the VA series came w/ Case mags, that were more dependable, and then distributors.
more parts are readily available for the VA. eventhough some are obsolete, the dealer carries most of them. with the V... well, good luck finding the sheet metal for one if you need it. if you do, expect to pay a princely sum.
the VA was more powerful than the V. the Continental/Case OHV engine proved better than the Continental flat head. later model VAs also came w/ the eagle hitch making them more versatile for use w/ implements compared to the power lift that was for use w/ a limited number of Case implements specific to that tractor.
the V is more sought after that the VA by some collectors because of the limited numbers built and the availability of some parts are found on other tractors. the flathead engine was also used on the Massey-Harris 101 junior as well as some combines.
id love to get my hands on an old VC. ill take one in almost any condition. as long as it has all the sheetmetal of course. lol.
hope this helps!
mike
Ken in KC
11-26-2003 19:29:03
 Re: Re: Re: Re: Information on Case VC in reply to Mike from Canada, 08-22-2003 07:55:04
I have come accross a Case VC, 1941 vintage. It has been sitting around a while and the brakes are all fouled up. The rear wheels were all locked up. We managed to get the rear axel appart and sure enough the brake straps are all coroded and need to be replaced. Any idea where I can find some?
Ken
Alberta Mike
08-21-2003 20:08:46
Just got finished a rather ugly job replacing the brakes on a V (wide front), same as yours pretty much other than the front end and steering. The V's (including VC, VO, VI, etc.) were produced from about '39-'42. They were pretty much a "jobber" tractor for Case since the company outsourced pretty much the whole tractor including the 4-cylinder flathead Continental engine. They were replaced in '42 by the popular VA series (overhead valve and pretty much Case-made parts and engine). I am in the process of restoring mine right now, neat little tractors I'd say. About 15000 of them were built ( as opposed to 150000 VA's). Most of them (12500) were like yours while about 2500 were like mine. Then there were a few hundred of the industrial and orchard ones produced. Contact me at the above email name link (I've removed the "hide" feature so you should be able to get to me directly by email. If not, use the following address:
[email protected]
