Triple Range
gatz
08-21-2003 09:28:55
I'm not a CASE owner, but could be one soon. I remember the 830's from the 60's as they were used by local de-hy and always seemed to run and run and run. Loved that styling.
My question is what is meant by the Triple Range transmission?. Is this a 12-speed?
(3 ranges x 4 gears) Are they synchronized?
Thnx, Gatz (is it ok to mention A/C in this forum?)
C. Amick
08-21-2003 09:55:31
 Re: Triple Range in reply to gatz, 08-21-2003 09:28:55
Yes, It does give you 12 forward speeds and 3 reverse. The triple range gear box has high, low, and direct drive. At least that's the way it is on my Case 300. No, the gears are not synchronized, you can't down-shift. The hydraulic pump uses the triple range gear box as it's reservoir. So, the fluid level in the gear box needs to be checked regularly.
