case 595 hydrualic trouble
billy70
09-28-2006 16:36:25
i need help with a problem i am having i replaced the hydraulic pump on the case-in 595 and it still is doing the same thing once you move the leveler into the raise position it takes a few minutes to start raising and it will lift what every it is hooked to ,u can rev the engine and it will raise what is the promblem here any help
PhilcaseinWPa
09-29-2006 06:05:55
 Re: case 595 hydrualic trouble in reply to billy70, 09-28-2006 16:36:25
I had a similar problem in my CIH 885. Had the pump replaced at the dealer. When I got it back it worked ok with a 6' bushhog. later in the spring I hooked up the plow and it wouldn't raise it or just raise it very slowly. Finally after several calls to the service dept and following their suggestions it worked ok. I don't think anyting they suggested really helped, I think it had air in the system. I didn't have any leaks in the system and the other hydralics and power steering worked ok. Later when I checked the fluid level it was way down. I posted on here about it and got a lot of suggestions. One was don't be afraid to overfill the hydralics. I didn't overfill but I made sure the system was filled. My owner's manual says park the tractor on a level surface and run it for 3 minutes at 1600 RPM, turn off the tractor and immediately check the fluid level. Have not had any trouble since. Knock on wood.
Phil
