international 585 water in oil
david macpherso
08-19-2003 18:21:31
I have a 585 that presented with a problem of water in the oil. i have removed the cylinder head and found no problems with the sealing of the head gasket. this is wat i have found.
1 no pitting of pistons or cylinder head
2 no oil in water
3 no pressure build up in radiator
4 no corroded core plugs
with the head off now wat is the best way to find the leak. I would be greatfull for any help
Elmer
08-20-2003 03:39:55
 Re: international 585 water in oil in reply to david macpherson, 08-19-2003 18:21:31
You probably have sleeve pitting. Remove the oil pan and pull the sleevs and pistons. Does the tractor have a coolant filter.
Bernard le m�cano
08-23-2003 19:04:43
 Re: Re: international 585 water in oil in reply to Elmer, 08-20-2003 03:39:55
Hi, like Elmer say,you have a coolant O ring leak. It have O ring, in the block, at the bottom of the cylinder sleeve. Bernard le m�cano Qu�bec Canada
