Model #
David
08-19-2003 10:55:03
I need to replace the points for the 48 case I am rebuilding, but the NAPA dealer shows 2 sets one for a Continental F124 and the other for VA,VAE S model. How do I know what set to get. The ser# for the Case AC5272419
Les...fortunate
08-19-2003 18:22:12
 Re: Model # in reply to David, 08-19-2003 10:55:03
There must be a V in front of that serial # which would make it a '48 VAC. Case engine.
David
08-19-2003 18:53:09
 Re: Re: Model # in reply to Les...fortunate, 08-19-2003 18:22:12
third party image
I am not for sure about the V, It could be there. I can make out the C.
JIM
08-20-2003 18:46:06
 Re: Re: Re: Model # in reply to David, 08-19-2003 18:53:09
hey u wouldnt happen to have any more pics of the tractor do ya, i just bought a 48 vac, the 3pt hitch thats on there looks like a homemade job, u wouldnt happened to have a pic of the 3pt hitch set up on yours do ya? thanks
David
08-21-2003 04:08:30
 Re: Re: Re: Re: Model # in reply to JIM, 08-20-2003 18:46:06
Jim,
Yes, here is the link.
David
08-19-2003 16:41:33
Thank You (Both), once again for the help!
Alberta Mike
08-19-2003 16:13:45
Yup, like the fella below said, the earlier V model Case (from '39-'42) used the F124 flathead Continental engine. Then in '42 Case replaced it with their VA series (overhead valve). Should be no problem finding parts for them, there were about 150 thousand of them sold in various models like standards, rowcrops, highcrops, orchards, industrials, etc.
C. Amick
08-19-2003 13:14:35
You shouldn't have the Continental engine. It was put in the older tractors. It should be an Autolite distributor and the Case VA engine. If you have the old points, they should be able to match them up.
