Case Eagle
Paul Ritter
08-18-2003 10:45:02
I recently inherited a cast iron replica of an eagle standing atop a globe of the world with "CASE" cast into the front of the globe. It's approx. 58" tall. It's got several layers of paint on it and I'm wondering if anyone can recommend the best way to clean it up. Can it be sand-blasted, or should a chemical paint remover be used? Thanks in advance for any suggestions.
Al
08-19-2003 14:40:04
 Re: Case Eagle in reply to Paul Ritter, 08-18-2003 10:45:02
If your Case Eagle is an Original Dealership Eagle you have a very valuable Eagle. (Anywhere from $5,000 to over $10,000 depending on its condition) If it is a reproduction then the value is less but still significant. Before you do anything you should have it looked at by a collector. If it is an original, you could damage it's value by attempting to restore it. I would have it appraised before I did anything to it.
Paul Ritter
08-20-2003 12:13:28
 Re: Re: Case Eagle in reply to Al, 08-19-2003 14:40:04
Hi Al: Thanks for the cautionary note on restoring the Case Eagle. I'm confident that the statue is the real deal as it was acquired by my dad from the local Case dealer about 30 years ago when the dealer closed up shop. Right now the bird is pretty unsightly, with light rust showing through the 2 or 3 layers of peeling paint; but it is complete including the 3-legged stand. Given its present condition, I would think that some clean-up would not hurt its value as long as the underlying metal is undisturbed. The question is, what is the preferred way to effect the paint and rust removal safely?
jerry
08-18-2003 17:51:41
Paul,
You are talking about alot of money standing in front of you.
Take it to some one that can restore it by removing the paint and keep it original. You are a very lucky person to have that Eagle.
That is my thoughts.
Paul Ritter
08-19-2003 07:49:36
 Re: Re: Case Eagle in reply to jerry , 08-18-2003 17:51:41
Jerry: Thanks for the heads-up on the potential high value of the eagle. I'll do some more research. Regards, Paul Ritter
