No Spark
David
08-18-2003 05:25:45
Can anyone help? Ref '48 Case (previous posting)Oil and battery changed. The engine turns over but not getting any "spark" to plugs. Points and condenser look ok. It was changed over to a 12v system sometime ago. Wiring looks very simple.
Don
08-18-2003 17:34:17
 Re: No Spark in reply to David, 08-18-2003 05:25:45
Check to see if you have voltage to the coil when the ignition switch is on. If not the problem is before the coil. If you have voltage to the coil, then the problem should be in the coil or points. I would replace the points, condenser, cap, and rotor. Maybe secondary ignition wires also. Make sure the base of the points is making good contact with the distributor. These are all general maintenance and should be done periodically. If still no spark you may have a bad coil.
David
08-18-2003 18:10:05
 Re: Re: No Spark in reply to Don, 08-18-2003 17:34:17
Don, Thanks.... I checked this evening and found voltage from the switch to the + and - side of the coil. I guess my next move, like you said, to change out the points.
