850 crawler dozer engine
j.tupitza
09-28-2006 16:29:42
I thought it was bad fuel so I changed both filters. Result engine starts but will not rev up. Blows black smoke out of the stack as it chugs along. I have bled out the injectors but no change. Anybody have an idea?
Paul in Ct
09-29-2006 05:01:53
 Re: 850 crawler dozer engine in reply to j.tupitza, 09-28-2006 16:29:42
Are you sure you're getting enough air? Sometimes oil bath air cleaners get water in the bottom and choke off the airflow
Roger (Mi)
09-29-2006 03:41:30
 Re: Did someone put gasoline in it? in reply to j.tupitza, 09-28-2006 16:29:42
Make sure the fuel is diesel fuel. Gasoline in a diesel fuel tank will cause running problems. If the fuel is really diesel, there is good flow to the pump, then you may have an injection pump problem. In that case, you'll have set the engine on #1, remove the pump, and take it to a diesel injection service.
