770 hydraulic pump
Jb
08-18-2003 04:28:07
has weak pump pressure is there anything I can do to the pump to get the pressure back? Thanks John
Jim Handke
08-18-2003 06:03:09
 Re: 770 hydraulic pump in reply to Jb, 08-18-2003 04:28:07
Are you going by the dash guage for pressure? Or have you plugged a guage into one of the remotes? If the power shift pressure(dash guage) is low, you can add shims in the flow divider to bring it up. If pressure is low at the remotes, the pump has to be replaced.
nna
08-18-2003 15:13:42
 Re: Re: 770 hydraulic pump in reply to Jim Handke, 08-18-2003 06:03:09
Before you replace the pump, check the relief valve.
Jim Handke
08-18-2003 20:23:01
 Re: Re: Re: 770 hydraulic pump in reply to nna, 08-18-2003 15:13:42
I guess I got ahead of myself. That's a possibility, although we've never had one go bad. Dad rigged up a home-made hydra-slueth, and we can check flow and pressure. Guess I shouldn't be so quick with my replies.
