Drop in transmission oil pressure on 2390
BB
08-17-2003 20:04:19
I have a 81/82 Case 2390 that is that is having a problem with low transmission oil pressure under the following conditions. As the clutch is released the transmission oil light flashs for a fraction of a second. This occurs just as the transmission engages. The same thing happen as the clutch is depressed. I have changed the transmission filter thinking that they might be pluged but this did not fix the problem. Other than this momentary drop in oil pressure very thing is working. I am getting a shop manual on this machine, but would like to hear from other that have had similar problems.
Thanks in advance,
BB
BB
08-20-2003 11:53:11
 Re: Drop in transmission oil pressure on 2390 in reply to BB, 08-17-2003 20:04:19
Thanks for the feedback. The PS works in all ranges. Since changing the filter I have noticed that the transmission oil light has started to flash when shifting the PS at low engine speeds. Since getting this machine I have put about 6 gallons of generic trans/hydralic in the transmission. About 4 gallons when I changed the filters. I suspect that the "cheap" lube may be part of the problem. Time for a oil change.
Thanks again,
BB
kyhayman
08-18-2003 03:30:07
I had a 2090 that did that. It did it from the day I got it to the day I got rid of it 10 years later. Talked to several mechanics. They all told me that it was just a sensitive sending unit. Did suggest that I change fluids to Hytran. I did and it helped. Stopped doing it when the fluid was hot.
What you are seeing (as they explained it to me) is a slight lag as the primary pump comes on line. Part of having a closed center hydraulic system.
Roger
08-17-2003 21:08:14
Is this happening in all 3 powershift gears or is pressure lower in second on the pwr shift? My 1370 would not pull in second after the bolts in the clutch pack broke, I could run in third on the range lever & first on the pwrshift with no problem to get done that spring. Mechanic told me Case heard about the problem & fixed it by putting bigger bolts ( 1/2 inch ) in the clutch pack on the 90 series tractors, the 70 series had 3/8" bolts when new, the holes get drilled for 7/16 bolts when fixed, not enough room for 1/2" in the 70 series, but I've never had any more trouble. I'de ask a Case mechanic if it could happen on the 90 series. If you can't find one that knows email me & I'll give you a number to call & find out
