LA Case questions
PoppinJohn720
08-17-2003 07:19:35
Yesterday I went and looked a a LA Case LP tractor up in northern Oklahoma. The tractor has been sitting in a barn for many years. The tactor looks to be in good original condition. The owner says it hasnt run in 30 years or so. I can crank the engine with the hand crank and there is antifreeze in the radiator. What are somethings that I should look out for on this model? What is a ballpark value for this tractor? The owner says the tractor is a 49 or 50 model but the chart on this website shows it to bee a 39 model. I dont think the chart on this website is correct because I dont believe the tractor is that old. The serial # is 329189 LA. Thanks for any help you may have.
RobertTX
08-18-2003 06:39:11
 Re: LA Case questions in reply to PoppinJohn720, 08-17-2003 07:19:35
The other guys sound in the ballpark on the price. It would be a conversion, there are lots of those in that area. One thing to consider - Ensign (manufacturer of the carb and other propane equipment) is no longer around. I have been told parts are not available anywhere, so that can be a problem. One option is to convert back to gas. Maybe someone with a parts spource for Ensign stuff will post?
Les...fortunate
08-17-2003 09:06:23
I'm guessing that there may be a 5 at the beginning of that number that is underneath the rivet or in some other way obscured. I had the same situation with an SC I looked at. On closer examination, I noticed the 5 that was partially obscured.
If there is a 5 there, that would make it a '49.
As to value, my brother paid something like $800 for one a year ago that had a stuck motor and he had to drive all the way to Minnesota from NH to bring it home. I'd say you have a potential jewel there. Knowing only what you have said, I'd offer $500 and see if he'll take it. That motor being free and it being under cover all those years is a HUGE plus.
martin in De.
08-17-2003 07:50:25
if its a LA, the serial No. you posted is incorrect. martin
mike
08-17-2003 10:19:29
 Re: Re: LA Case questions in reply to martin in De., 08-17-2003 07:50:25
The tractor is worth more than 500.00!!!!! !! The head will bring 500.00 or more. Offer the man 1500.00 . There are not many LA propanes left in the world, get in on the ground floor of this restoration opportunity!
mwfarm
08-17-2003 22:54:28
 Re: Re: Re: LA Case questions in reply to mike, 08-17-2003 10:19:29
I'm from northern OK, and there are plenty of LP 's around here. Almost half of the tractors were either bought LP, or converted.
JW
08-17-2003 16:47:58
If its a 49 it isn't factory LP. They weren't introduced until 52 according to Full Steam Ahead. If the tires are okay and its all there you should be safe up to 800 or so.
