Case 2090
Tom Schmidt
08-17-2003 04:55:10
I recently purchased a 2090 that has not been used easily. The only real problem is the eight speed tranny. It doesn't shift into gears very easily. And when it is put into park it doesn't stop rolling. Any suggestions would be helpful. It has 7500 hours.
john m
08-17-2003 10:01:42
 Re: Case 2090 in reply to Tom Schmidt, 08-17-2003 04:55:10
Hard shifting can be helped by replacing cables. OEM cables are too long, measure distance needed to connect lever to control and have a local auto, or truck supplier (NAPA?) order\make cables of proper length. Also, stub shafts connecting shift arms to forks can rust into trans hsg. Park problem is either a broken key locking park gear to pinion shaft or park lever not moving into park gear. Remove trans cover on RH side, where the 2 4spd cables are clamped in place, to check out.
SHeiserman
08-17-2003 05:34:53
I don't know about the hard shifting problem, but we had a 2390 that would on occasion break the park linkage. Pretty simple fix. I'd put a new rod in myself, as the second time that it broke, it broke right beside a weld. Good luck
