Air cooled Case
Kennyp
08-16-2003 16:02:29
In Mike's pictures, I assume that is an air cooled engine used on a combine. Last page 2, first page 3. The drawings all way intreged me. Were they as bad as reputed? How heavy were they?. In my younger days I wanted one for a ground effect machine..... ..
Kennyp
08-16-2003 21:03:33
 Re: Air cooled Case in reply to Kennyp, 08-16-2003 16:02:29
The only info I have says the 6 foot G and A (pull) combines had Wisconsin engines, while the 9ft M and 12ft K had there "own". Funney thing tho is they give the bore and stroke for there "own" engines as the same as Wisconsin 4 cylinders. Isn't the Case air cooled a 6 cyl inline? All of the Case swathers I have seen were built by Heston with various Winconsin air cooled V4s. BTW: Wisconsins start OK if you grind the valves, keep the dirt cleaned out so the valves run cooler and don't burn. Course I all ways jump started mine with a 12 volt battery to there 6 volt starter. he, he.
JayEyeSee
08-17-2003 08:48:56
 Re: Re: Air cooled Case in reply to Kennyp, 08-16-2003 21:03:33
The case air cooler was 4 cylinder same bore and stroke as a VA series engine. The only wisconsins I have seen that case used was V-4s not inlines although wisconsin made a inline 4 air cooler. The early Case combines used wakausha engines the same as the R series tractors. I have never seen a air cooler Case in a combine only in tobbaco setters, but they show being used in model 75 and 77 combines. The Case air cooled is model A125 engine.
keith
08-16-2003 19:05:39
Case put some air cooled engines on swathers.
DKase
08-16-2003 18:26:34
There is a guy in MN that has one of these in his VC tractor. There was some discusion if it came that way from the factory, but you could tell it was a baler of combine engine that had been stuck in. I do have some parts books and stuff for the air cooled Case engine if someone needs part numbers. Good day folks!
John Saeli
08-16-2003 17:20:23
Hey KennyP; I got one of them engines. My Dad said they were a good engine. Had the Wisconsin beat, especially after dinner. The CASE would fire rite up. Looks just like the "V" engine except for the air cooled jugs.
Mike Schotte
08-16-2003 17:39:30
 Re: Re: Air cooled Case in reply to John Saeli, 08-16-2003 17:20:23
John,
If I'm not mistaken... that WAS a Wisconsin engine in the photo.
-Schotte
John Saeli
08-17-2003 10:37:58
 Re: Re: Re: Air cooled Case in reply to Mike Schotte, 08-16-2003 17:39:30
Hey Mike; Look a little closer. Has anyone seen a 4 cyl in-line air cooled Wisconsin? I have one.
Oops... a pic
08-16-2003 17:55:36
third party image
third party image
