SC Magnito
fredCT
08-16-2003 11:32:17
I am restoring a 44 SC and I am working on the magnito. My question is how do I reinstall the rotor and properly align the gears for timing? I am talking about the small drive gears behind the rotor. There is a small dot on the smaller gear but none on the rotor gear. Thanks for your help. FredCT
Kennyp
08-16-2003 11:46:04
 Re: SC Magnito in reply to fredCT, 08-16-2003 11:32:17
Fred, on all I have worked on there was some kind of mark. Dot or the corner of the a tooth filed off. Like the corner off on two teath and the rotor dot matches to that. If not, you are going to have to set it so that the rotor just gets on to the distributor contact as the points OPEN. Some mags can be set for either rotation where the roror gear fits on its shaft. Watch out you don't change that, if it is that kind of mag.
Mike Schotte
08-16-2003 11:44:49
FredCT,
From my 4-JMA Magneto Service Manual:
"The tooth over the red dot on the steel gear must mesh between two beveled teeth on the distributor gear.
THE BEVEL ON TWO TEETH ON THE CANVAS BASE BAKELITE DISTRIBUTOR GEAR MUST BE ON THE SIDE OF THE GEAR NEXT TO THE DISTRIBUTOR DISC.
If the bevel on the teeth is on the side away from the distributor disc, the gear is not assembled properly on the shaft and should be turned over."
Hope this helps, -Schotte
