Need info on old Case
dan
05-05-1999 16:52:36
I have a Case wheeled tractor. I would like to find out about. It has a possible add on hydraulic 3-point set up. What kind of oil to use in the transmission and hydraulic unit, and how much. I runs ok, should I adjust the valves? What clearances and firing order. Where can I get a maintenance manual? The serial # is 416575SC. Thanks to any one responding. Dan
HOLD ON GUY'S !!!! we have deception in the court
05-08-1999 04:48:06
 Re: need info on old Case in reply to dan, 05-05-1999 16:52:36
the SC serial no# start at 4500001 in 1941
Go to your spring of "99" issue page 25
If Dave Erb did his research correctly #41657
would make this tractor A model "L" Shaun
1937 model L
05-08-1999 05:15:32
 Re: Re: need info on old Case in reply to HOLD ON GUY'S !!!! we have deception in the court, 05-08-1999 04:48:06
Dave
05-06-1999 19:37:31
Reproduction manuals can be purchased by writing to:
J.I. Case Corporation
Tractor Products Group
700 State Street
Racine, WI 53404
martin Williams
05-06-1999 11:23:19
This tractor is too old to have an original 3pt.
Eagle Hitch on it. The serial number tells me
that it is a '37 or '38 model SC. Positive.
The firing order is 1-3-4-2, and i know it will
pull a full 2 plows. Holds about 7 quarts of motor oil, and will hold about 10 gallons of rearend oil. I have a DC, which is bigger, so these capacities are not exact. Radiator will hold 5 gallons. Good luck. If you need to know where to get parts, e-mail me.
TMAC
05-05-1999 19:31:53
Dan; your serial number tells me its a '38 model SC(I could be VERY wrong). Do like I do. Go to a major book store and find a Case-specific tractor book. The books will answer most of your questions and you will see for sure what kind of Case you have. As for the 3pt hitch, It will most likely be Case's Eagle hitch. Again pictures from a book will answer.
Dug G.
05-05-1999 18:08:57
Looks like you have a 1941 Case SC tractor. Afraid I cant remember the capacity or clearances, but i would check with a TSC, or even tis site for a maintenance manual. Good luck!
TMAC
05-05-1999 19:34:04
 Re: Re: need info on old Case in reply to Dug G., 05-05-1999 18:08:57
I didn't read Dug's reply before putting in mine. Go with his answer of Case model.
