300 throttle friction plate
Gary
08-14-2003 20:05:04
what was used to hold this handle leather or cork or? have it all tore down. dealer no help!
Scott KY
08-15-2003 18:40:09
 Re: 300 throttle friction plate in reply to Gary, 08-14-2003 20:05:04
A friction disc for the throttle on a 135 Massey Ferguson worked fine on my Case 400.
Kennyp
08-14-2003 22:37:34
Gary, do you mean that block on the right side of the engine? I just looked at mine and appears to have no material. Just a perfect fit of metal to metal that slides. Or is there some thing else back under the tin work?
gary
08-15-2003 06:06:23
 Re: Re: 300 throttle friction plate in reply to Kennyp, 08-14-2003 22:37:34
no this is where tension is held on the throttle handle. if you follow the shaft down right under the dash sheetmetal there is a spring tensioned disc which in between some sort of material is usedwhen I heated up the disc a little had sort of the smell of cork!!
Jim M
08-15-2003 09:49:11
 Re: Re: Re: 300 throttle friction plate in reply to gary, 08-15-2003 06:06:23
When I put my 351 back together the friction disc I got from the dealer was a cork one
Jim Handke
08-15-2003 09:46:39
I used a piece of inner tube on my 830.
John M
08-15-2003 07:01:57
I used some cork gasket material from the hardware store for my restoration. Works wonderfully!
