930 Case engine swap
Lary
08-14-2003 18:22:01
How hard would it be to swap a diesel engine into a Gas 930 ? thanks in advance Lary
Ricky
08-20-2003 08:30:31
 Re: 930 Case engine swap in reply to Lary, 08-14-2003 18:22:01
A 930 lpg will use 8 to 9 gallons of fuel per loaded hour if that will you. I would think about 7 gallons per loaded hour.
Roger
08-15-2003 19:12:52
I can't think of much other than needing a fuel return line back to the tank that the gas tractor doesn't need. I'm not sure if a bigger radiator would be needed or not. I've got both gas & diesel & never paid much attention to each on radiator size.
Lary
08-15-2003 20:34:26
 Re: Re: 930 Case engine swap in reply to Roger, 08-15-2003 19:12:52
Roger; How much fuel does a 930 gas use per hr? It will be used for doing hay. thanks, Lary
Roger
08-15-2003 22:17:27
 Re: Re: Re: 930 Case engine swap in reply to Lary, 08-15-2003 20:34:26
I'm not sure yet, I bought mine 2 years ago, used it part of that winter then had transmission lock up & finally got it fixed this spring, so I haven't had it in the field under a big load yet. I wouldn't think it would use that much haying
