Old Case tractor
Kent
05-05-1999 16:00:58
Have located a reasonably priced old Case tractor I'm considering buying. The number on the plate near gages has the number VA 5055087. There is a number cast into the side of the transmission housing VT 164 with a B underneath. I need advice. Will there be parts available for this tractor? What is the model? This seems to fit what I'm looking for which is a project to work on restoring but don't want to run into deadends finding parts etc. Thanks to all that respond.
martin williams
05-06-1999 11:27:29
 Re: old Case tractor in reply to Kent, 05-05-1999 16:00:58
You have a Case VA tractor. Engine parts are fairly easy to find, just expensive like anything
else. Neat little tractors will pull a light 2 plows, and are easy to haul around because they are small. Go to >Link
parts.
toolbox
05-05-1999 18:41:03
You've found a 1946 VA. Parts are still reasonable to find, but some items are a little more difficult. Seems like the VA's are getting more in demand lately. Good luck and have fun with it.
Dug G.
05-05-1999 18:04:09
Looks to be a 1946 model VA tractor. There pretty easy to find parts for. Good Luck!
