730 wiring diagram
CASE4ME
08-14-2003 12:44:18
I have a 730CK gas tractor and I am putting it back together after painting. The problem is electrical is my weakest area of knowledge. When I went to putting the dash back together some of the wires came of ign. switch and I am not sure if I got them back properly. I have looked at the IT manual and the Case parts book for the tractor but, neither shows a close up of the ign. switch. Does any one have this info or know where I can get. Any help is greatly appreciated.
Phil (NJ-AZ-SK)
08-17-2003 03:39:30
 Re: 730 wiring diagram in reply to CASE4ME, 08-14-2003 12:44:18
Caseforme, The general Rule for Wiring the Ignition
switch..
B = battery and has a wire coming from one side of the ammeter. (the other side of ammeter has the wire from Bat)
I = Ignition and has wires for you gauges.. etc.. Light Switch (may be fused)
S = Start and has Wire going to the Starter Solenoid..
Hope this Helps
CASE4ME7277
08-19-2003 10:41:23
 Re: Re: 730 wiring diagram in reply to Phil (NJ-AZ-SK), 08-17-2003 03:39:30
Thanks for your help that should help me narrow down the wires I still have a couple in question. thanks again
Roger
08-15-2003 18:25:12
Look and see how many terminals the ign. switch has. It looks like it may have three according to my book. See if they are marked with the letters I, B,& S
