300 muffler
Kennyp
08-14-2003 09:35:17
Did the 300 round nose have a muffler? Mine has the exhaust down and back umder the axle. I just replaced the exhaust manifold and think I will install one. Don't like the idea of that exhaust blowing back on dry cheat grass while I am bush hoging. Be a little safer with muffler wouldn't it? BTW: replacing the manifold is fun with the sheet metal on and a loader in the way..... .
Kennyp
08-14-2003 17:14:36
 Re: 300 muffler in reply to Kennyp, 08-14-2003 09:35:17
When I crawled under with the cutoff grinder, I found the pipe was actually two pieces. Larger front section was correct size for the muffler. Muffler pinches a bit against the axle. I wonder if after I build a bracket for the back end, if I should try to heat the pipe up and bend it a bit so that there is no pressure on the manifold. Would hate to crack that valuble manifold.
C. Amick
08-14-2003 10:05:15
I bought a horizontal type muffler for my 300 from v a l u - b i l t tractor parts. It sets just in front of and under the axle.
Kennyp
08-14-2003 11:42:44
 Re: Re: 300 muffler in reply to C. Amick, 08-14-2003 10:05:15
I had Big-R order me one several months ago. Quite reasonable. Looks to be maybe 1/8 to 1/4 inch big...no problem, I will find a piece of thin tubing to adapt. Intend to make a bracket just to the rear of the axle for the outlet.
Thanks, Kenny in Colo.
gary
08-14-2003 19:54:46
 Re: Re: Re: 300 muffler in reply to Kennyp, 08-14-2003 11:42:44
just finished my second 300 roundnose.this bracket idea I came up with is to use the original threaded bosses at the rear of the tractor next to the drawbar angle iron. I used angleiron 1x1 bolted that to the case and held my muffler into the downpipe used the muffler clamp end and welded a piece of 1/8 flatbar to it and the angle ironlooks nice and clean. at tractor supply I used a muffler from an allis challmers. good luck!
Thanks Gary
08-15-2003 09:10:12
 Re: Re: Re: Re: 300 muffler in reply to gary, 08-14-2003 19:54:46
Thanks Gary, looks like I am going to do the same.
