830 Case-O-Matic fluid change
LD5030
08-13-2003 05:18:01
Looking for some advice from the Case gurus....Picked up a '62 830 diesel with the Case-O-Matic a few weeks ago that needs alot of attention. Going through changing the fluids and was wondering the best approach to the C-O-M. Can or should I flush it with diesel or something else? Also what is the best fluid to use for replacement? I know you can use ATF, but the stuff that's in there now isn't red and wondered if it would be wise not to switch. This is my first experience with a C-O-M, but from what I have researched from this site it seems to be operating OK. None of the gauges work so I don't know pressures/temps. Thanks,jim
Nate Schmittgens
08-15-2003 06:19:27
 Re: 830 Case-O-Matic fluid change in reply to LD5030, 08-13-2003 05:18:01
Jim,
You can use ATF, also acceptable are Case TCH fluid as well as Hy-Tran. System requires 18gal. Flush system with clean oil, I wouldn't reccommend using diesel fuel; not that it wouldn't work, but, if you are running the machine while flushing the fuel is to thin & doesn't contain enough lubricity. If you have any questions, feel free to call Steve or Nate @ (314) 966-6692. Thanks!
SHeiserman
08-15-2003 18:36:47
 Re: Re: 830 Case-O-Matic fluid change in reply to Nate Schmittgens, 08-15-2003 06:19:27
The torque converter housing only takes 4 gallons. I've never heard anyone here say anything about flushing it, but I'd agree with you about using the correct oil to flush it.
LD5030
08-18-2003 06:07:49
 Re: Re: Re: 830 Case-O-Matic fluid change in reply to SHeiserman, 08-15-2003 18:36:47
SHeiserman, Thanks...I was a little confused. I have the I&T manual and didn't think the clutch/transmission/ hydraulics were all a common system fluid wise.
Am I correct assumimg the transmission and hydraulics use common fluid. The manual says 10.5qts for hydraulics and 17/18gal. for the transmission, but when working on the tractor with hyd. pump and pto cover removed I started the machine for a few seconds and noticed fluid being introduced into the hyd. resevoir. I kinda think although the two don't actually share the same fluid they aren't totally isolated from each other either. The hyd. weren't working at all when I got this and found that a couple of the links and pins from the throwout collar on the pto broke and ended up in the pump due to a broken screen on the intake tube. I need to find another pump and possibly the valve housing too.
Thanks,jim
Thanks
SHeiserman
08-18-2003 15:00:45
 Re: Re: Re: Re: 830 Case-O-Matic fluid change in reply to LD5030, 08-18-2003 06:07:49
Yep, the transmission and hydraulics use the same reservoir- 18 gallons (I have Hy-Tran in there too). Don L , who posts here regularly, could probably help you out with parts. How close are you to Iowa?
LD5030
08-18-2003 18:11:33
 Re: Re: Re: Re: Re: 830 Case-O-Matic fluid change in reply to SHeiserman, 08-18-2003 15:00:45
I'm in Southwest Michigan. The wife is from Moline,IL and I get over there every so often. Have a cousin getting married in Des Moines end of September so I'll be over there then.
Thanks,jim
SHeiserman
08-18-2003 18:41:54
 Re: Re: Re: Re: Re: Re: 830 Case-O-Matic fluid cha in reply to LD5030, 08-18-2003 18:11:33
I don't think there is another C-O-M case within a billion miles of here.What are the odds your cousin is a Sullivan or marrying one?
LD5030
08-19-2003 07:30:37
 Re: Re: Re: Re: Re: Re: Re: 830 Case-O-Matic fluid in reply to SHeiserman, 08-18-2003 18:41:54
No relation to Sullivans. She's a S. Dakota native working/living in Iowa now. I don't need any parts specific to C-O-M. You wouldn't know if the hyd. pump and valve housing from a 900B would swap to the 830? There's been one sittin' in the weeds right next to me for the 9yrs. I've been here.
SHeiserman
08-19-2003 14:47:37
 Re: Re: Re: Re: Re: Re: Re: Re: 830 Case-O-Matic f in reply to LD5030, 08-19-2003 07:30:37
Sorry, can't help with the hyd pump question. Try another post- somebody will know. Good luck in your quest for parts and answers (as opposed to the parts of answers I give). Have fun
Phil (NJ-AZ-SK)
08-17-2003 03:29:12
SHeiserman, I have a 530 CK that developed a leak in the Clutch Control.. Fixed the Problem... but because the Trans Hydo Fluid I am using is Clear its hard to see the level on the Dipstick... Result: over filled the sucker... I would like to change to something with a "Color" ...
Any suggestions?
SHeiserman
08-17-2003 05:22:45
 Re: Re: Re: Re: 830 Case-O-Matic fluid change in reply to Phil (NJ-AZ-SK), 08-17-2003 03:29:12
Hy-Tran Ultra (from the CaseIH dealer) is red. There are so many different choices for oil, I don't know which one is best, but Hy-Tran is what the dealer sells for C-O-M.
Sheiserman
08-13-2003 17:04:00
I'm not a guru of any sort, but my owner's manual doesn't say anything about flushing it. All it says for service is to drain and re-fill torque converter housing and breather every 240 hours. As far as oil goes all I've ever used is HY-TRAN ULTRA or Champion 4000 universal. Sorry it doesn't answer the question, but it's all I have. Good luck
