730 Diesel Head Leak
Rollin
08-12-2003 18:31:14
Cleaned off all the grime from my new 730 Diesel and found the source, a head gasket leak between the heads. Any tips on changing the gasket, it looks pretty simple.. comments from someone who has changed one ?? Thanks Rollin
Dale in Tx.
08-12-2003 20:11:34
 Re: 730 Diesel Head Leak in reply to Rollin, 08-12-2003 18:31:14
Hi Rollin, Be sure and replace the freeze plugs,problay what is leaking,Be sure to put the manifolds on BEFORE you tighen the head bolts,are you are apt to have an exaust leak! not good. Dale in Tx.
keith
08-12-2003 19:13:23
Had a valve job done on my 730 diesel heads this spring. The head gaskets are pretty easy. Make sure everything is really clean. After I torqued the bolts down I ran the engine for about 45 minutes then torqued the bolts again this is important. I just followed the service manual instructions and it worked out.
RobertTX
08-13-2003 07:51:24
 Re: Re: 730 Diesel Head Leak in reply to keith, 08-12-2003 19:13:23
Second what Keith said. The manual for the 500 specs to retorque while hot, think this is important. You may have to make a tool to get the nuts under the rocker shafts. I bought a cheap wrench and bent it to make a custom crowfoot extension.
