need info on this model.. I'm new to case/ih, etc
souNdguy
08-12-2003 05:07:37
third party image
Any info is appreciated. I saw this on the side of the road.. price looked attractive..
thanks
John H-WI
08-12-2003 08:46:44
 Re: need info on this model.. I'm new to case/ih, in reply to souNdguy, 08-12-2003 05:07:37
Just a few things to look at- does it start easy and is there any smoking when it runs or idles. Check the radiator and see if no oily look. The other thing is antifreeze in the oil. Not sure how you check this unless you drain some out. You can check the clutch, brakes, and transmission by driving it. Of course when you are dealing with 50 year old units they seldom are perfect but thats the fun of bringing them back. Put a paint job on that girl and you have a sharp unit. You can tell the year of manufacture by getting the serial number, 7 digits and subtracting 4 from the first two digits of the serial number. The model number is included with the number. It should be on a plate on the dash below the steering column. If thats gone its stamped on the block on the left side on the rear of the block. Good luck.
souNdguy
08-12-2003 10:37:22
 Re: Re: need info on this model.. I'm new to case/ in reply to John H-WI, 08-12-2003 08:46:44
Thanks for the info. Pretty much the same stuff I had to watch out for on my old fords I bought ( 8n and NAA )
Thanks.
I'm heading over now to testdrive.
Soundguy
Paul f
08-12-2003 05:30:32
It is a DC3. Excellent tractor (have one myself) Strong about 38 hp in later models. Built from about 1939 to 1954. Parts are fairly easy to obtain (except pistons and sleeves which are available but pricey. Later models had live PTO and Eagle Hitch (similiar to a 3pt), which was Case's way around the Fergusson patent.
souNdguy
08-12-2003 05:43:12
 Re: Re: need info on this model.. I'm new to case/ in reply to Paul f, 08-12-2003 05:30:32
Thanks for the info. Anything I should know before I go ask to test drive it.. any pecularities.. or gotchas...
How is hte clutch aranged.. pedal style right? I'm not ready for any hand clutch tractgors yet!
Thanks
Soundguy
Paul f
08-12-2003 05:55:49
 Re: Re: Re: need info on this model.. I'm new to c in reply to souNdguy, 08-12-2003 05:43:12
Sorry but only the very last DCs had foot clutches...but I had never had a hand clutch before and it has some advantages. I use mine for mowing and snow removal and haven't had a real problems. You will need a suicide knob for the steering wheel so you can steer one handed...(they steer really easy) Backing up and using hydraulics and steering all at same time is a bit of a Chinese fire drill.
dctom
08-12-2003 18:11:30
 Re: Re: Re: Re: need info on this model.. I'm new in reply to Paul f, 08-12-2003 05:55:49
you have a late model DC3 and they had much more than 38 horse, the first ones had that but yours should be close to 50 if it is in good shape and you will love that hand clutch once yu are use to it
souNdguy
08-12-2003 06:08:38
Well.. I'm adventerous... I guess I'll put my hat on sideways and go take a crack at it.. the price is soo good I may have to learn that 3 hand driving thing....
Soundguy
