smallest Case farm tractor?
Lew
08-11-2003 20:02:51
Not counting riding lawn mowers, what model Case tractor was the smallest? How many years was it produced? Did Case every make anything comparable to a Farmall Cub or a Massey Pony?
Lew (again)
08-12-2003 20:35:02
 Re: smallest Case farm tractor? in reply to Lew, 08-11-2003 20:02:51
Thanks a bunch everyone. Lew
I believe a VC would be t
08-12-2003 06:21:06
A vc is light enough that it can be pulled in a 2500 lb. class if you take the fenders, and maybe the battery out. But it is a much stonger tractor than a cub or pony. It uses the same continental Block as some of the bigger Massey's.
Mike Schotte
08-12-2003 05:58:16
The 10-18 crossmotor was pretty darn small.
third party image
-Schotte
Frank
08-12-2003 03:52:05
The model R or it's successor the S probably took up the least floor space. Standard tread small sized tractor was also made in orchard version, R began in '30s , was replaced by S, made until the early 50's
Mike from Canada
08-12-2003 00:13:45
the VAS is the smallest in the VA series of farm tractors. they built 1,559 between 1951 and 1954. 1951 being the most rare with a total of 18 built for that year.
they were a single-row cultivator for vegetables and small trees. i put a link to a picture in the next post.
hope this helps!
mike
Arthur
08-12-2003 03:34:10
 Re: Re: smallest Case farm tractor? in reply to Mike from Canada, 08-12-2003 00:13:45
Wasn't the V series a little smaller than the VA series?
Mike from Canada
08-13-2003 00:54:50
 Re: Re: Re: smallest Case farm tractor? in reply to Arthur, 08-12-2003 03:34:10
well... yes and no. the V used a standard front axle which set it low to the ground, that indeed makes it small but even tho the VAS is considered a hi-crop tractor, its narrow compared to the V and that makes it small too.
the VAS is also offset and that compares to a Farmall A/Super A and i think thats what Lew wanted to know. the V is more like a Cub Lo-Boy. they could both be considered the smallest tractor. the thing is they both use the same size power train (engine&driveline) as everything else in the V/VA series.
i hate it when i cant make up my mind.
mike
dctom
08-12-2003 18:15:03
no the va series was smaller than the v seeries not much but some
Mike from Canada
08-12-2003 00:06:49
heres a picture of a VAS.
hope this helps!
mike
Alberta Mike
08-12-2003 21:18:49
 Re: Re: smallest Case farm tractor? in reply to Mike from Canada, 08-12-2003 00:06:49
I assume that the S stands for a sugar cane model, is that correct?
Mike from Canada
08-13-2003 00:29:21
 Re: Re: Re: smallest Case farm tractor? in reply to Alberta Mike, 08-12-2003 21:18:49
umm, im not entirely sure. i thought it stood for "short". cotton/cane models were narrow crop tractors that usually used a single front wheel.
i may be wrong but it sounds good dont it?
mike
Dave
08-13-2003 08:56:01
 Re: Re: Re: Re: smallest Case farm tractor? in reply to Mike from Canada, 08-13-2003 00:29:21
The "S" stands for "side" since on the VAS the main body of the tractor was shifted to the left.
My vote for the smallest 200B series
my $.01 worth
