S C CASE BRAKES
Bill Jones
08-11-2003 17:39:19
I am having a heck of a time with replacing brakes. How do you get them off and who has replacments for them? Thanks Bill
C. Amick
08-12-2003 09:30:15
 Re: S C CASE BRAKES in reply to Bill Jones, 08-11-2003 17:39:19
Sometimes the discs are stuck to the splined shaft. Is that the problem you are having with removal? Is there anyone in your area that re-lines brakes and clutches. I get mine re-lined locally. They charge $20 to $25 per disc. There are 7 carbon steel balls inside each brake assembly. I think 3 of them are 3/8" and the other 4 are 1/2" or vice versa. I've been buying new stainless steel balls instead of polishing the old ones. The ones I am using are made of type 440-C stainless, which is almost as hard a carbon steeel. I order them from the McMaster-Carr Company. They have a web site. I got a generic package of automotive drum brake parts at NAPA. There are some parts in this package (springs, etc.)that I have been able to make work on the Case SC brakes. Hope this helps.
Bill
08-12-2003 11:37:11
 Re: Re: S C CASE BRAKES in reply to C. Amick, 08-12-2003 09:30:15
Thanks for follow up on the brakes. Getting off is a problem it looks like. is there any easy or best way to remove? No one around here relines brakes. can you give me someone so when i get mad enough to remove i can send to get them done. Thanks
C. Amick
08-12-2003 12:11:45
 Re: Re: Re: S C CASE BRAKES in reply to Bill, 08-12-2003 11:37:11
I usually drive large screw drivers or what ever else I can find in behind the disc to wedge it out. I hammer things in at several points around the disc. I sometimes bend the disc a little, but it can be straightened later by hammering after removing the old lining. If you have the gear oil drained from the transmission, you might try heating the center a little with a torch while prying. I'm in WV. Tell me where you live and I will see if I can find someone that re-lines them that is close to you.
Bill jones
08-12-2003 18:23:16
 Re: Re: Re: Re: S C CASE BRAKES in reply to C. Amick, 08-12-2003 12:11:45
Thanks for follow up on brakes. I have been practicing on a vegetable tractor i have before i start on wide front case i have. The distance of west vir is no problem for ordering. i do have the oil out so guess i will try heating and prying again. i"ll let you know how i make out, but you could send me your supplier of plates,thanks bill
C. Amick
08-13-2003 05:51:36
 Re: Re: Re: Re: Re: S C CASE BRAKES in reply to Bill jones , 08-12-2003 18:23:16
I've never bought any replacement SC brake discs. I've always been able to get mine re-lined. If you are looking to buy the whole disc you might try Don Livingston 507-433-0073 (mornings) or [email protected]
Bill
08-15-2003 08:40:57
 Re: Re: Re: Re: Re: Re: S C CASE BRAKES in reply to C. Amick, 08-13-2003 05:51:36
Sorry i really meant to ask about getting them relined thanks bill
