trans fluid 530 case
Alan Flaatten
08-11-2003 16:02:26
wanted to change transmission fluid in triple range trany. manual says 90 wt fluid - says may need to be thinned down for winter use with light wt oil. i was wondering if there wasn`t something that would work good for year round use. Any help would be greatly appreciated. Alan in Wisconsin
Dennis/Ohio
08-17-2003 03:48:43
 Re: trans fluid 530 case in reply to Alan Flaatten, 08-11-2003 16:02:26
Hi Alan, After you have drained the torque tube. Look inside the hole and you'll see another drain plug that takes a allen wrench. Dennis....
Steve Schmittgens
08-15-2003 19:38:29
Alan, use Case TCH or HY-TRAN (type A will work also) in the front half of the transmission and 90 wt in the back half of the transmission.
Any questions call me at 314-966-6692 Steve
John Saeli
08-11-2003 17:42:52
Hey Alan; From my own experience, I reccommend 85W-140 gear lube in there. Leave it in year round.
Alan Flaatten
08-11-2003 18:38:24
 Re: Re: trans fluid 530 case in reply to John Saeli, 08-11-2003 17:42:52
Thankyou for the info John, I`ll give it a try.
Thanks again, ALAN
