Case VIC electrical
Burnell
08-11-2003 11:02:35
Trying to get 6 volt generator to work right. Does anyone have a wiring diagram showing where the leads should go. On the original light switch there is a fuse or resistor? what is it's job? can you get a replacement?
Alberta Mike
08-12-2003 21:21:55
 Re: Case VIC electrical in reply to Burnell, 08-11-2003 11:02:35
Email me (I've removed the "hide" from my email link. I could tell you a bit about the wiring and that 3-position light/generator control switch.
Mike from Canada
08-12-2003 00:24:31
does the generator have a cut out or a regulator?
i used the CaseIH parts catalogue to wire up my electrical on my 49 VAC.
its a 5A fuse that goes into the light switch. theyre available anywhere.
hope this helps!
mike
