Thermostat Removal
Don
08-10-2003 14:14:14
I have located the thermostat. How is it removed from the cast water reservoir? I removed the elbow, but can not get the thermostat out of the reservoir. The spring portion of the thermostat was in the elbow. Is that correct?
Thanks for any help.
Don
08-11-2003 04:32:13
 Re: Thermostat Removal in reply to Don, 08-10-2003 14:14:14
That was my plan. I still can not remove the thermoostat. It is hanging from the top of the cast water reservoir.
Kennyp
08-10-2003 23:54:16
You probably all ready know this but, to check it, put it in a pan of water on the stove. If it don't open when boiling, throw it. I got pretty good at changing thermostats when I drove a 75 Chev pickup. When they quit, they quit closed and you did not move until you removed them. Out on the road.
