Case RC
Ken
05-04-1999 17:06:24
A friend recently purchased a 1938 Case RC that I am helping him to restore. We are looking for someone who has worked on one of these to help us along with the project. We will be needing a supply of parts ( front wheel hub for a dual front wheel, air cleaner system, brake covers and one brake). Also needed is the proper paint code for the light gray that was original for the tractor. Wendels notebook lists a lite grey for the R and Unstyled RC. Is the 1938 styled or unstyled? Thanks for any info!
Dug G.
05-05-1999 18:16:17
 Re: Case RC in reply to Ken, 05-04-1999 17:06:24
If its a 1938, it shouldn't be styled. If it has any trace of orange paint and the grill is cast iron with a design that goes vertical sort of like firework explosion then it is styled.
Dave
05-06-1999 20:09:15
 Re: Re: Case RC in reply to Dug G., 05-05-1999 18:16:17
I have two 1938 RC's. one is styled, the other is unstyled. The reason for this is some unsold 1938 RC's were upgraded with a new hood and grill and repainted to look the the new model that was introduced in 1939. Most of these tractors kept their flat top fenders instead of the new clam shell fenders that were introduced with the new models. Also you will find a 4th gear in the upgraded tractors but it will not be marked on trans cover. As for the paint the light gray on most RC's I beleave is not correct. The RC gray should be a little darker. I have a formula for the darker color but the light gray is very close to Ford NAA
JHH
05-07-1999 02:35:44
 Re: Re: Re: Case RC in reply to Dave, 05-06-1999 20:09:15
Have a '37 RC that we restored. Paint was matched with a spots of original that we found on fender brackets etc. The Ford grey is too light. Email me for formula. I can also send you a chip.
See pictures at: www.personal.psu.edu/users/s/j/sjh182/
