Case VAC paint scheme
MattWV
08-09-2003 17:53:05
I have recently acquired a 1946 VAC that has been a family tractor since it was new. My questions are: What is the correct color for the two bottom plow? What is the correct color for the cultivators? It has a rear hitch with three points to connect but it is not an Eagle hitch. And the points of contact on the lift arms are much larger than a traditional three point hitch. Does anyone know what this type of hitch is called.
Thanks
Mike from Canada
08-10-2003 09:48:11
 Re: Case VAC paint scheme in reply to MattWV, 08-09-2003 17:53:05
the plows and cultivators should be painted green. JD green is close.
the hitch at the back is called a power lift. it runs off a pump at the belt pulley.
hope this helps
mike
MattWV
08-10-2003 10:00:55
 Re: Re: Case VAC paint scheme in reply to Mike from Canada, 08-10-2003 09:48:11
Thanks Mike,
I want to get this tractor painted soon for my great aunt. She is 87 and had the tractor since it was brand new.
Nicholaus Sowder
08-09-2003 18:33:12
Could you show us some pictures of your Vac? Like the plow and cultivator and tractor please. I think the plow would have green and maybe the cultivator too. Thanks
