VAC Hydraulics
Theo
08-07-2003 10:13:04
I have a 1948 VAC with a 2 bottom plow. The tractor has a high pressure hitch with hydraulic pump on belt pulley drive. Everything works wonderfully, except for the fact that it will not hold the plow up. It lifts with ease, does not leak, but will not hold. Any suggestions would be greatly appreciated!
Joe (Wa)
08-11-2003 21:57:36
 Re: VAC Hydraulics in reply to Theo, 08-07-2003 10:13:04
Hi Theo, I just ran across operation & servicing info on your high press system in the back of one of my VAC manuals. About 10 pages, fairly detailed. I can copy and mail if you want it.
Joe
Send e:mail [email protected]
C. Amick
08-08-2003 10:47:18
Mine leaks down as soon as you shut the tractor off, but stays up when running. It may be leaking past he pressure relief valve. Check to make sure the springs and balls are in there and seating properly.
Dave
08-07-2003 11:18:37
I don't know all differances between your 48 and my 50 VAC but I'll share with you what fixed my hydraulic issue. I had fuild dripping out of the air breather under the steering colum and the system wouldn't hold for any period of time. I replaced the ram cup on the hydraulic piston and that made a big differance. No more leaking, and much improved hydraulic performance. The part is still available from CASE for $20.00 or so. Replacing all the fuild may help too. I don't think the 48 has a hydraulic filter but I may be wrong. Good Luck! There are a lot of smarter CASE guys on this site who can provide you with even better knowledge I'm sure. Take Care
