Case 430 Starting Problems
Rob Meyer
08-07-2003 06:27:35
BEen having Some problems with getting the diesel started. At first - the starter engaged and ran quite a few time - but it wouldn't start. First time ever. I figured I had some water or just plain bad diesel. Drained everything - refilled and primed. Try to start but it was acting like I ran the batter down. I jumped it off the truck and got it running, Ran fine - I used it for about an hour and then shut it down. went back to get it started after cutting some trees down and it wouldn't start.
It would engage the starter - but then the bendix would drop out after a second or so.
Took the battery out - charged it - load tested it and put it back in. No Luck. Put the battery in from the truck - no luck. Same thing Starter would engage but then drop out.
Today I will put new ends on the battery cables - NAybody have any thoughts on a possible starter problem?
scott from hawaii
08-07-2003 11:13:09
 Re: Case 430 Starting Problems in reply to Rob Meyer, 08-07-2003 06:27:35
Sure sounds like you've got it narrowed down to the starter. You can have them rebuilt for pretty cheap (about $90 in Hawaii) My 530 was doing the same thing. My strter was turning and it sounded okay, but just wasn't spinning fast enough to make the deisel pop.
HTH
