Question on ID of a VA rear power lift ???
Alberta Mike
08-06-2003 18:24:11
A lot of VA Cases I have seen have some sort of a rear power lift. It is made from heavy bent flat bar steel (not cast like the true Eagle hitch). I have seen the same unit on many VA Cases. It has a manual control on one rear side for the height adjustment of the unit ... and another manual control opposite side for the tilt adjustment. What is the name of this hitch and who made them? It was operated from those VA's with the high pressure pump mounted on the right side torque tube (some even had the belt pulley built in with the pump). It was not the Eagle low pressure unit that had the pump attatched to the right front of the engine. Was this a real 3-point set up or some other configuration? I thought at first that it might have been a home-made outfit but I've seen too many of them for that.
Mike from Canada
08-07-2003 11:43:51
 Re: Question on ID of a VA rear power lift ??? in reply to Alberta Mike, 08-06-2003 18:24:11
the pump is called a Kingston pump. the linkages are unique to specific implements like a plow (the two manual controlls) as far as i know it was called a "power lift" and it was made by Case as the predecessor to the Eagle Hitch. some call it the original Eagle Hitch but it doesnt have the unique claw style catches they were famous for.
was this on the VAC your friend bought? just curious.
mike
Alberta Mike
08-07-2003 14:48:05
 Re: Re: Question on ID of a VA rear power lift ??? in reply to Mike from Canada, 08-07-2003 11:43:51
No, that VAC I told you about has the actual original factory Eagle Hitch (with the pump on the engine, front right side). I'll email you a photo one of these days when I get one. The one I'm asking about is on a hulk sitting at one of my friend's farms and I've seen a number of them. I was just wondering what they were and if Case actually made them.
