Starting a Case diesel
George
08-06-2003 15:22:03
Not being around other Case diesels, I don't know if this is normal or not.
When I looked at the Case 900 which I bought the owner sprayed a short shot of starting fluid in the intake breather stack. The tractor then started right up. The owner said he always did it when the engine was cold (regardless of the air temperature).
The few times I've started it since then with the engine cold, I've had to give it a short shot of starting fluid to get it to fire off.
Question: Is this normal for most Case 900 (or similar models) diesel engines? Or is this a sign that something isn't right or the engine is getting tired?
Also the owner used the decompression lever when starting the engine, but it seems to me from reading the manual that the decompression lever is only used for manually cranking the engine like for adjusting the values.
Any comments on when to use or not use the decompression lever?
Shane
08-07-2003 10:31:30
 Re: Starting a Case diesel in reply to George, 08-06-2003 15:22:03
The first thing I would check is the injection pump timing. Had an Allis 7045(god for bid) that was addicted to either. Wouldn't start in 90 degree temps, checked and adjusted the timing and fired instantly after that. Now the dumb thing has tranny problems. Any one want a nice Allis 7045? Ha!
George Best
08-07-2003 10:36:59
 Re: Re: Starting a Case diesel in reply to Shane, 08-07-2003 10:31:30
Shane you may be right. I talked to a Case collector last night and that was something he suggested to check. I don't think the engine is tired as after it warms up a bit it runs without smoking and sounds great when the throttle is opened.
Chris Brown
08-06-2003 19:16:17
I've had a few experiences where the supply pump on the injector pump was going bad and a shot of ether would make it pop right off. A short tow start would do just as good .the old pump just cant do it's job at cranking speed,but runs fine after the engine is turning. pull start it at about idle speed and see what happens,if it pops and hits on one or two cyls and takes a few seconds to smooth out and run ,the engine is probably just getting tired. But if it turns over slow and starts running fine all of a sudden as the speed is increased ,I'd look at the pump.
Garry
08-07-2003 05:54:59
 Re: Re: Starting a Case diesel in reply to Chris Brown, 08-06-2003 19:16:17
I think Chris is right on the money. I have a case 930 that starts on the first turn every time.
caseman-d
08-06-2003 18:09:16
Well if he has to use either in this kind of weather there is something wrong. It could be low compression, maybe valves needing adjusted, or maybe it's just addicted to the either. Another possibility would be worn injector pump, timming or fuel leaks. Once you get it running check your fuel pressure to make sure you have good fuel pressure. Should be at least freezing before you should have to either start it.
caseman-d
RoyG
08-06-2003 15:38:03
If the 900 engine is in good shape and the batterys are good it should start with NO starting fluid. Good batterys and good starter should turn engine at 400 rpm. The decompression lever can be used to get a cold engine to turning good for cold weather start or for any time you need to turn engine by hand. It will not hurt anything to use it any time.
Barnyard Rebel
08-06-2003 20:08:48
 Re: Re: Starting a Case diesel in reply to RoyG, 08-06-2003 15:38:03
No.1 problem, tractor is a case
No.2 problem, tractor is addicted to either
Shane
08-07-2003 10:27:38
 Re: Re: Re: Starting a Case diesel in reply to Barnyard Rebel, 08-06-2003 20:08:48
You can stick it and keep your crap in the other discussion boards for what ever tractor makes you think you are king.
Roger
08-06-2003 23:32:08
Rebel, If you don't like Case tractors why don't you go elsewhere or keep your damn comments to yourself
GeoMo
08-07-2003 06:00:32
 Re: Re: Re: Re: Starting a Case diesel in reply to Roger, 08-06-2003 23:32:08
Way to tell him Roger.
I bet he has green blood.
