Question about timing mark
Garry
08-06-2003 06:52:18
I was told my 1963 Case 930 CK timing shoud be set at 31 degrees before TDC. I have examined the fly wheel and the mark is at 20 degrees before TDC with about five notches in front of the 20. Do I guess at where 31 degrees is or is the 31 not correct? Any help is appreciated.
MGM
08-07-2003 03:06:41
 Re: Question about timing mark in reply to Garry, 08-06-2003 06:52:18
Garry
That may have been me, did you check on the pump side of your valve cover gasket, This is where my timing degrees is stamped. It was on my middle valve cover. My 930ck is a 1967 so The data may be different. Let me know how you fair out. I will also check my manual tonight on the timing marks on the pulley for you.
Mike
Garry
08-09-2003 05:54:16
 Re: Re: Question about timing mark in reply to MGM, 08-07-2003 03:06:41
Mike, were you able to find what the timing is on the 1963 Case 930? thanks for your help, Garry
Garry
08-07-2003 05:16:43
Mike, thanks I will check there. I had more than one person say the timing should be 31 degrees but as I mentioned the timing mark doesn't look that way. I will look on my valve cover tonight also.
