930 CK
Rev JJ
08-05-2003 21:03:31
Jsut bought a 1969 930 CK Diesel. What can I expect? Hos do you keep the brakes working?
JCMarleau
08-06-2003 19:00:09
 Re: 930 CK in reply to Rev JJ, 08-05-2003 21:03:31
I you need a part manual my email is [email protected]
Jim Handke
08-06-2003 05:49:22
Just keep the tractor in a shed. If left outside, rust builds up in the brake pads. That leaves iron against iron, and that won't stop your tractor very good. I've had minimal trouble with two 30 series tractors with seal trouble, and that's a good tip you received about installing them.
hoop
08-06-2003 01:22:34
stub shaft seals may be leaking, have to replace seals and brake discs, you can replace seals without pulling the carrier, you will need to find a plastic bottle to slide over shaft to protect seal while installing, remember that if it's a case, brakes are a problem.
