Unleaded Gas In VAC?
Nels Ebbesen
05-04-1999 08:19:10
I just purchased a '49 VAC and wondered if there is any problem running unleaded gas in the motor. Some older engines need lead or lead substitute to lubricate the valves and protect them from wear. Also my radiator cap has a paper/cardboard gasket that is in bad shape. Is this a pressurized system? Could a neoprene gasket from a newer radiator cap be used for a replacement? Thanks.
Elmer
05-05-1999 04:53:05
 Re: Unleaded Gas In VAC? in reply to Nels Ebbesen, 05-04-1999 08:19:10
I bought a 44 massey from a fella who said the engine only had 200 hours since rebuild. Got it home and found one exhaust valve leaking. Valve was burned due to unleaded gas. Have used lead substitute since. Automotive machinist strongly recommended it.
Marty
05-04-1999 13:02:29
As far as the gasket goes I cut up an automotive thermostat gasket to fit..It's not neoprene but it will be resistant to antifreeze/water/steam.
C. Amick
05-04-1999 10:04:44
I don't think unleaded gas will harm your engine in the short term. It would probably take several years to do any damage. I always put a little lead substitute in mine when I add gas. No, it is not a pressurized system. Yes, I think a neoprene gasket will work.
