Case records
Milan
08-05-2003 19:26:47
Are there production records somewhere that could tell me if Case built a SC with a S front end in 1946? We have a SC (serial #tag) with a S front end. Thanks
Milan
Milan
08-06-2003 09:11:10
 Re: Case records in reply to Milan, 08-05-2003 19:26:47
thanks Mike, Martin, JM and Brian,
The tractor has adjustable wheels on the rear axle. I didn't write the serial # down but I remember it starts with 50. If I get it done, I will try to put a picture on but that will take awhile since I am old and I am a Norwegian. Again, thanks.
Milan
Mike Schotte
08-06-2003 06:17:08
Milan,
Here are some links to YTMAG forum archive posts that you may find helpful. I promised Kim quite a while back that I'd write an article on how to order these things... but I still haven't done it yet. (Rich only works part time for Case, so it may take a while to reach him:)
Archive Post- Photo of a Case build sheet
Archive Post- Build sheet ordering info
Regards, -Schotte
martin in De.
08-06-2003 06:11:20
Milan,you can get a copy of the build card from case that will show how the tractor came out of the factory. The last one I got cost seven dollar,thats cheap for good information I think.
JM
08-05-2003 20:20:57
Are you sure its a 46, according to what I've read Case didn't build any SC tractors in 46 due to a union dispute
Brian in Ohio
08-05-2003 19:39:48
DOes the serial number on the tag match the one stamped on the tractor? Look on the driver's left side, where the engine and transmission meet, and it should be stamped along that ridge. It can be hard to see if it has been painted over multiple times, so have a wire brush handy to clean that area.
My first thought is: someone has changed the serial number tag, and this tractor is an "S" and not an "SC".
