Case SC
Theo
08-04-2003 08:59:18
I have a 49 SC. Compression is good, spark is great, gap in the plugs have been checked, manifold on tight, carb rebuilt. In any case, it basically runs on two cylinders. I can pull the wires off of spark plugs 3 & 4 and hear no noticeable difference. When a gap is created between the plug and the wire, the spark arcs and the engine runs better. When the wire is on the plug - nothing. I've tried different plugs and larger gaps and still no results. Any help would be greatly appreciated as I am getting frustrated with this one!
Klyde
08-05-2003 09:59:29
 Re: Case SC in reply to Theo, 08-04-2003 08:59:18
Sounds like fouled plugs and a hot mag to me. You said different plugs ie. not NEW ? swap 3&4 with 1&2 plugs and see if the problem follows the plugs if not then its either the cap and wires or the (maybe valve springs too) rotor. Have had this problem before and i was usually too cold a plug for todays MODERN gas. Additves are know to cause this problem. ie. FAKE lead and other octane boosters. leave them out dont worry about the valves and seats, burn them up and then have the head rebuilt with the hard stuff. And if your not workin it HARD don't worry at all.
Jim in MI.
08-04-2003 18:30:50
I think you have some plug wires reversed. Try reversing plug wires 3 and 4 and see what happens. Jim
Larry
08-04-2003 14:29:12
Make sure you have the correct firing order. You could have 3 and 4 reversed.
C. Amick
08-04-2003 09:37:57
I need to think about this one. All I can think of right now is that the timing could be off. Have you tried turning the distributor or mag with it running to see if this helps?
