SC fluid capacities
Eric Rylander
08-03-2003 19:55:33
OK, so I know I need a manual but....
WHat is the oil sump capacity on a SC? Should I use muti grade?
Trans/final drive housing, use 90 wt and how much?
Hydrauic system (no Eagle hitch)
I am going on vacation to where my SC is being stored and plan to spend a day with it, I have new plugs, and oil filter and a plug wire kit (solid core NAPA wires) to bestow upon her. Just need to know how much oil to change everything while I am there.
Eric Rylander
Aaron
08-04-2003 10:36:59
 Re: SC fluid capacities in reply to Eric Rylander, 08-03-2003 19:55:33
Jimmy is right, 6 qt. single grade oil in engine. Use 11 qt in hydraulics, and my book says 17 gal in transmission.
jimmy
08-03-2003 21:13:52
The 90 wt is 10 3/4 gallons/ I beleive 6 quarts of motor oil w/filter , Use a straight Viscosity, 30 or 20.
C. Amick
08-04-2003 09:41:02
 Re: Re: SC fluid capacities in reply to jimmy, 08-03-2003 21:13:52
If it has the lifting bail, I believe the hydraulics reservoir holds 2.5 gallons.
Eric Rylander
08-04-2003 14:34:52
 Re: Re: Re: SC fluid capacities in reply to C. Amick, 08-04-2003 09:41:02
It has hydraulics, no lift bail, but no Eagle hitch, though I wish it did!
Eric
