Mountiing Oil filter?
08-03-2003 13:44:16
Got a canister oil filter off an SC today, but must have been later model or such. I don't have the holes in block to mount the bracket. AND, I don't seem to have the return hole in my block side. There is a bigger plug in what may be the oil gallery under the starter area, but would think that would be "pressure" side, correct? There is a small screw-like head to right of that, that is pretty much flush, not sure what that is. The pressure side/line for filter runs off a tee that goes in where gauge reads above starter. Do you guys have a way to use this filter that I can try or am I SOL on early tractor? Mine is a 41, think first year?? Seems to be lots of changes along the way for this model.
